I have a 65 comet and I'm redoing a lot of the wiring and setting up new electric things like an electric fuel pump. I ended up attaching several wires to the hot side of my solinoid and everything is running ok, but it looks sloppy and bulky, I was wondering if I could just run one larger power wire from the hot side of the coil to a fuse panel? I think it should work the same I just want to ask and make sure it will work before I redo everything I've done so far. It works and I would leave it but whats down there now is so messy and confusing and not properly labeled. So I figured I would do some work now to save myself a headache when something fails later. Thank you for your input.
