I was planning to build my own C4 but I was pricing parts and can to a total of 1400$ for pan, transbrake, billet survos, hardened shaft, alto clutches, new pump, new billet planets, is all these parts really needed???
Will a C4 hold up to 900-1000 hp with just a good servo, cluches and hardened shaft or are all the other part really needed??
I doesn't seem that bad of a deal just to buy the 1800$ rollerized bad boy from Performance automatic.com. Anybody run that C4 or any of the competators C4 and how much power are they holding.....
Thanks, Scott
I have ran a PA C-4 for close to 10 years. This is by far the best tranny I have had in my 25 years of racing. My engine makes 750 N/A & I have a NOS Big Shot set on kill. Only thing about them is you must keep the proper fluid level & synthetic fluid ain't cheap. Best unit I've seen.
anyone know what is supposed to be so special about PA pump because they sure are proud of it if all it is is a stock one with new gears and removed cooler check valve. any thoughts?
I looked at mine closely after disassembling it and found 2 holes are larger than stock on the stator support but I didn't notice any check balls or springs missing. Just the roller #1 thrust and 2 larger holes is all I found. I still need a digital camera to take compare pics of the PA C-4 parts next to the stock C-4 parts since all 5 C-4s are now all apart to get all 5 cases machined for the roller against the case on the inside and the rest of the parts machined for rollers. The holes on the PA Super Pump I have between the sealing rings are still the same size as stock. Only 2 holes on the front face where the pump mounts to are larger.
