what tooth flywheel came stock on a '69 small block c4 mustang??
Back in 69, I bought a 2K mile 302/C4 combo out of a totaled 68 Torino to use in a boat that I was building at the time. The flywheel/flexplate had a 160 tooth ring gear. Ford used 160 teeth ring gears more than most realize on both auto and manual transmissions. The 160 and 157 tooth ring gears are interchangeable on the "small" flywheels; while the 164 tooth gears are used on the larger flywheels (typically on 351Ws and 351Cs).
I would have to say it came with a 157 tooth flexplate since me 68 Cougar had a 157 stock in it.
