From a 1961 Comet S22 a complete drive train coming available. I6 engine and 3SPD manual. 34k on odometer. Runs, shifts and drives as it's in the car now. Was told it's a 170ci. brand new ignition, good clutch oil pan to air cleaner, water pump to trans tail shaft. Generator charges, choke works drop in ready as I see it. This video is from the first start, later drove it around the neighborhood.
Exhaust manifold leaks at engine side gasket. Engine fan and spacer, clutch pivot not included but again air cleaner to oil pan, water pump to tail shaft are. Fuel pump, sending units, generator, fuel lines are included $800.00
Possibly the 7.5" rear end, front spindles attached to brakes, rear brakes (all brakes new) and, 4 bolt rims (5 total) might be sold as well, havent decided if I'll use the until rebuilding the new parts.
