Hey Guys and Gals. I have a question to put to you all. My daughter has a 1961 Galaxie - 352, 3-speed overdrive, manual steering - that we are having a devil of a time trying to get to steer correctly. The only thing that we haven't done is replace the center link. The pitman arm end of the center link has some play in it and I can't find anyone who can tell me if the rebuild kits for these center links will fix the pitman arm end. I've already replaced the idler arm bushings.
The car has been to the front end shop and supposedly put the tires in a straight line. But, when you drive it, the tires squeal and leave a set of double black marks on the road. It jumps all over the road when you go over a bump and you have to fight it to keep it in your lane.
Has anyone any info on doing a donor swap to a later model suspension and steering? I've been looking on the forums and see where the '03 and up Crown Vics will donor to trucks, but what about the cars?? Any help would be appreciated. Don't limit me to only the CVs. If there are other donors that can be used, please let me know. Thanks.
