I have replaced the spark plug wires and distributor cap as well as the voltage regulator and ignition coil. The engine will crank but I checked the spark plug and there is no spark. It's a 390 ThunderBird V8.
Does anyone have any idea what I should check next?
Thanks.
Yep.... the Points gotta open too.... Not too much and not too little... Make sure the points lead is hoked up under the dizzy cap....
FE
Sure Norcal, but there ain't no spark so it really don't matter as of yet....
For what it's worth, my '63 (with a fairly new 390 crate engine) wouldn't start this past spring. It would kick a bit, but wouldn't start. Checked everything (or so I thought). It was running a bit rough when I parked it in the fall, but didn't think anything of it. Turned out that the pin holding the distributor gear was broken. I got a spark every now and again, but not enought to "run." I was unable to troubleshoot the problem myself, so I had to have it looked at by a "professional." Took him about 5 minutes to find the problem.
