This may speak more to my search capabilities than anything else, but....I have what appears to be the original - at least correctly dated for my car - T10. My question is simple and I am sure it is out there but can't find the answer. Is the input shaft a 10 spline, 1 1/16 inch? Or would it be different? What I have found points me in that direction. Thanks in advance.
Numbers off the trans will help to determine all of that and then we can tell you if its original...generally theres a tag on the trans which is usually easy to findif its not caked in grease ....i believe the only two size inputs are 1 1/16 and 1 3/8....david key has a trans code identifier that once we have the numbers we can help more.
Bill's tranny is a Borg Warner T10 not TopLoader...
