Life was busy the last week, preventing me from making much progress on the Gal after last week's shakedown drive. We were able to get back in the garage last night and knock out some new and remaining items on the Galaxie last night after fixing some minor things on the friend's truck.
- Headlight adjusters - didnt have any luck finding a cage nut the same size as the OE headlight adjusters. Created a temporary solution with a plastic square expansion nut and the factory piece. Re-aimed the headlights as best we could on the garage wall. Need to complete a final adjustment.
- Removed the radiator shroud and added two(2) 5 inch Spal fans to the passenger side of the radiator. Each 5" fan is rated at 340cfm in addition to the 16" fan that was previously connected to the shroud. Wired the new fans to the same relay as the 16".
- Thanks to NumberDummy on the ford-trucks forum, I was able to find the correct temp sender for the factory gauge. RockAuto is useful when it comes to cross referencing OEM part numbers; OEM Temp sender. Either the sender I got at advance was bad or was the wrong ohm range. The factory gauge works and sits dead center when the engine temp is roughly 175 degrees.
- Before the engine was reinstalled, a 1" front sway bar was installed. After last weeks drive and the new coils settling a bit the clearances over the front control arms were tight to non-existent. Shortened the endlinks a bit to roll the bar back towards control arms and prevent contact with the front of the control arms. Hopefully this removes the intemittant clunk heard from the front of the car.
- For anyone re-wiring the car with a KwikWire harness, beware the instructions suck. We noticed the front running lights would go off when the headlights were turned on. Turns out there is a small note at the bottom of the instructions(corrections?) informing users to connect the front running lights to the same blade on the headlight switch as the rear running lights if OEM operation is desired. Problem corrected.
We let the car idle in the garage up to temp last night with an ambient temperature of ~60, all 3 fans kicked on as intended, and it took roughly 2 minutes for the temperature to drop from 176 back to 169 and the fans went off. I'll need to dial in the Fan ON/OFF temps via the Holley after driving it a bit more. Hopefully this means itll have a chance staying cool during hot NC summer evenings. The plan is to drive it this afternoon for errands to confirm the shroud was preventing airflow during the last test and continue to flush out any other issues. For now, pictures!
The lack of room between the W/P pulley and 4 core radiator makes it difficult to run a shroud with the proper depth. The little 5" fans pull ~2.5amps, no noticeable impact on electrical system when running based on the voltage gauge.
Factory"dummy" temp gauge works with the new sender! The sender is located in the return heater core hose because the holley temp sender is in the main intake bung. The engine wasn't quite to full temp yet, which is why its below center in the picture.
