I just picked up a 1964 Galaxie 500 4 dr. When the headlights are used the outer most (Dims) are all that come on, reguardless of Brights or Dims. The inner (Brights) sockets only register 3.3v on meter. Also with the dims, one side is brighter than the oter even though I changed the bulbs.
Any suggestions on making them all work correctly?
As for one of the low beams being dimmer, that is a ground issue. Check the ground on the radiator support and make sure it is in good condition.
