1 - 9 of 9 Posts
I bought a 64 Ranchero. It has the original rearend in the car (6 cyl, 4 lug, drum brake). I’m putting a 302, a C4, and disc brakes (eventually) to make it a functional street rod. The questions/problems I’m having are:
  • what rearend is going to fit
  • what is a good gearing towards economy and power balance
  • should I find a used and build or buy a cut to length 9 inch
If anyone has any good ideas for what I should do, I’m all ears. I’m trying to do as little modification as possible minus the cut to length option.
An 8" out of a '64-'65 V8 Falcon is a bolt in I believe, assuming the spring pads are in the same locations. Mine has 2.80 gears, which gives me between 17-21 mpg based on the last big road trip I took, and it's got plenty of oomph off the line. Pretty durable unit behind a small block.
Font Material property Number Screenshot Parallel
That's a handy list to have; if you can find any of those cars or the rear end from one. I haven't done it yet, but from what I've read in the Ranger forums, a 90-92 Ranger with a 4.0 engine will come with an 8.8 rear end that is in the 56-57" range, has spring perches already on them, and frequently come with Traction Loc. The only down side from your standpoint might be the ratio. A lot of them had 3.73 and 4.10. although I've heard of 3.08's. ( I plan on using one with a 4.10 and then put in an AOD. ) Best part is they are available and affordable, and actually stronger than an 8". They do have a different driveshaft connection, but Hemmings.com had an article on the 8.8 that listed a part number for an adapter. Just one more option.
1 - 9 of 9 Posts
