A 64, 65 or 66 Mustang is exactly the same except for the length, you have to adjust that anyway. You'll have to take your existing dash mount and drill out the rivits to get it off your old column then just figure out the alignment by measuring your originals location and spot weld it on. If you want the original look without the emergency flasher knob opening on the right side these are the years to use. 67 and later have the emergency opening for the knob on the right side. You can get a 64,65,or 66 column off ebay or a swap meet for $15 to $75 just depending on the seller. An original 64 4 speed column, if you can find one, would cost you $200 plus. Also just use the turn signal control that is for your Fairlane. The original steering wheel fits correctly.
