I'm looking for a good set of the door opening inside filler panels for my 66 fastback.
Do you have those?
Thanks, mvannote
Hi there mvannote, sorry for the slow reply. I don't have the bracket or filler panels you are looking for, but surely they are out there.Also looking for the lower radiator mounts/brackets. See pic. Just needing the bracket.
See last reply as well for the filler panels.
Thanks for your reply. Appreciate the efforts anyway.Hi there mvannote, sorry for the slow reply. I don't have the bracket or filler panels you are looking for, but surely they are out there.
I don't recognize those panels you have pictures, but if they go between the metal door jamb and rear door panel, then they're tough to find. Problem is they are thin hard plastic and unfortunately they become very brittle as they age. If those are the pieces you need, you may have to scour the internet and reach out to guys with `66 Galaxies on Ebay and Craigslist.
There are also junkyard search engines out there but problem parts like these is rarely anyone uses the proper name given by the parts book, so trying to find it via those searches is pretty difficult. Having pictures helps a lot because you can email them to people ...
Lastly, if you'll be keeping your car for a while and/or you will continue working on it, I recommend buying a Ford MPC parts catalog on Ebay. If you can't download it from Ford Muscle Forums, then they are available on CD disk for about $20. That way, you can look at the exploded diagrams for every assembly on the car, plus you can find each name and part number you need. That helps your search.
Sorry I couldn't be of more help.
Mvannote - consider this ... if you come up with a good mold on those pinch weld trim pieces on the door jamb (under rear panels), and you find they come out pretty nice, you should seriously consider making 10 sets. It would be easy to sell them to `65-66 Galaxie owners here and on Ebay or elsewhere. Everyone has problems with them breaking, cracking, splitting, etc.Thanks for your reply. Appreciate the efforts anyway.
We decided to mold our own filler plates to replace the originals using a vacuum forming machine. It's the same way we will be making the tray for the custom center console when we start to design and make it later down the road.
I do have an original 66 shop manual for my car. It does help a lot over the course of time. I bought that the same week I bought the car.
This car will be staying in the family. I've received offers on it while it's been in the shop uncompleted.
I have a set of '65 radiator brackets. They would need to be cleaned up a bit, but are solid. Took the original pair I had and had to weld on extensions to fit the larger aluminum radiator.Also looking for the lower radiator mounts/brackets. See pic. Just needing the bracket.
Thanks Hemicharger99. I appreciate it.I have a set of '65 radiator brackets. They would need to be cleaned up a bit, but are solid. Took the original pair I had and had to weld on extensions to fit the larger aluminum radiator.
Please do. In the meantime, I had to paint mine black to match the new interior and plasti-fix them back together. I know they won't hold up.Thanks Hemicharger99. I appreciate it.
I did find a set locally believe it or not. Couldn't find them online and then found a Craigslist ad for other items, requested if he had them and wahlaa. Couldn't believe it.
When we get to the point of making those pinch weld trim pieces, I'll add the pics/etc on my thread and see if your still interested.
Hey gang - I have a bunch of parts leftover from my years long restoration, many which were accumulated since 1995. All parts are used unless otherwise noted. If you’re interested in anything, make an offer via private message. I have pics of all which I can send you, be sure to include your email address.
Thanks - Roger
PS - it may take me a bit to get back to you. I'll also try to keep this list updated over time.
AC - Compressor Caps. NEW
AC - Compressor Bracket Mount, powdercoated
AC - Expansion Valve, NEW
AC - Hose Grommets, Radiator Support - pair, NEW
AC - Factory Ford Hoses
AC - York AC Compressor
Body - LH front fender, 1966 Galaxie
Body - Front Fender Bracket
Body - Door Hinges, Front, 1966 Galaxie Fastback
Body - Hood Hinges, Used
Body - Radiator Support Bracket, NOS
Body - Radiator Support Bracket, USED
Body - Vent Window Frame Assembly (without glass), RH Side
Body - Vent Window (with glass), LH Side
Body - Vent Window Set (with glass), R-L
Body - Rear Quarter Glass, Set of 2 with Hardware
Windows - Rear Quarter Glass, Set of 2 with Hardware
Body Grille - Grille Fins (2 pcs), Set no.1 (8 of 10)
Body Grille - Grille Fins (2 pcs), Set no.2 (7 of 10)
Body Grille - Two piece Grille set, set no.3 - needs re-chroming
Body Emblems - F-O-R-D trunk-hood letters, 1965 Galaxie NEW
Body Emblems - F-O-R-D trunk-hood letters, TWO sets plus extras, 1966 Galaxie
Body Emblems - F-O-R-D trunk-hood letters, TWO sets, 1966 - needs re-chroming
Body Emblems - Ford Front Fender Emblems, Galaxie Star Type 1966
Body Emblems - Galaxie 500 “Block” Rear Quarter, with Black Paint
Body Emblems - Galaxie 500 “Block” Rear Quarter, with FADED Paint
Body Emblems - Hash Type for Rear Roof Pillar, set of 6
Body Emblems - Hash Type for Rear Roof Pillar, set of 5
Body Lamps - Tail Lamp Set with lenses & bodies, pair
Body Lamps - Parking Light Assemblies, Lot
Body Lamps - Tail Lamp Frame & Backup Light Set, chrome parts only
Body Lamps - Tail Lamp, body housings, pair, USED
Body Trim - Antenna, NOS
Body Trim - Door Mirror Matching Set, original NOS, some tiny scratches, 1965-66 Ford Galaxie
Body Trim - Door Mirror, Drivers Door, used
Body Trim - Rear Rocker Mouldings 1966 Galaxie XL, LTD & 7-Litre
Body Trim - Drip Rail, 4-Pieces, RH/LH sides, Set No1 1966 Galaxie Fastback XL, LTD & 7-Litre
Body Trim - Drip Rail, 4-Pieces, RH/LH sides, Set No2 1966 Galaxie Fastback XL, LTD & 7-Litre
Body Trim - Drip Rail, 4-Pieces, RH/LH sides, Set No3 1966 Galaxie Fastback XL, LTD & 7-Litre
Body Trim - Drip Rail, 1-Piece, RH Passenger Side 1966 Galaxie Fastback XL, LTD & 7-Litre
Body Trim - Drip Rail, 2-Pieces RH/LH sides, 1965 Galaxie Fastback
Body Trim - Door Edge/Guard Mouldings, 4-Piece Set, DAMAGED
Body Trim - Door Handles, Exterior, Set of 5
Body Trim - Headlight door - single, RH, NOS
Body Trim - Headlight Trim Rings, pair
Body Trim - Hood Lip Trim - 5 Piece Set - (no.1)
Body Trim - Hood Lip Trim - 5-piece Set - (no.2)
Body Trim - Hood Lip Trim - 4 Piece Set
Body Trim - Rocker Mouldings, LOT of 3 (one extra)
Body Trim - Rocker Mouldings, Set No1
Body Trim - Quarter Window Sill L Trim, LH Side
Body Trim - Quarter Window Sill Trim, Exterior, Set No1
Body Trim - Quarter Window Sill Trim, Exterior, Set No2
Body Trim - Front Window Trim - Exterior, 3-piece Set
Body Trim - Front Window Trim - Exterior, Complete Set
Body Trim - Rear Window Trim - Exterior, Complete Set
Brake - Adjustable Proportion Valve
Brake - Master Cylinder Cover & Clip
Brake - Master Cylinder Rubber Seal
Bumper - Anti Squeak Seals, rear bumper
Bumper - Support Brackets, front
Bumper - License Plate Lamp Assembly, Rear Bumper
Center Console - Lid Door, USED (light dent)
Center Console - Stainless Trim, Set No1 (goes along sides of center console)
Center Console - Stainless Trim, Set No2 (goes along sides of center console)
Center Console - Stainless Trim, Lot of 3 Pieces (goes along sides of center console)
Center Console - Push Button Switch & Latch
Charging - Alternator Autolite Dual Belt
Charging - Battery Hold Down & Tray set
Charging - Battery Hold down J-bolt set, NEW
Electrical - Voltage Regulator Harness – NEW
Electrical Horns - Horn Plate, NEW
Electrical Horns - Horn Relay, NEW
Electrical Horns - Set of Hi-Lo, 1966 Ford
Exhaust - Original Ford Exhaust Brackets, Lot
Engine - Air Cleaner, Moroso Gasser Type
Engine - Air Cleaner, original-type Ford HiPo, chrome with blue base, a few marks on chrome otherwise VERY nice
Engine - Air Cleaner Decal, 289 Ford Air Cleaner, NEW
Engine - Air Cleaner Wing Nut, Exact Repro 1966 Galaxie, Mustang, Ford
Engine - Coil Bracket nut & bolt set, original parts 1966 Ford
Engine - Fan Spacer for Water Pump (3-inch)
Engine - Intake Manifold ($600.00) Cobra Jet - C8OE-9425-C, date 8H1. Dual plane cast iron. Originally installed on all 428 CJ/428 SCJs. Great shape with no chips, cracks, heli-coils. Should restore beautifully.
Engine - Power Steering Belt, 15450, NEW
Engine - Power Steering Pressure Hose, 1965, NOS
Engine - Power Steering Pressure Hose, 1966, Nice
Engine - Power Steering Pressure Return Line Clamps, set of 4, NEW
Engine - Power Steering Pump, 1966 Galaxie Mustang Ford PS Pump, Original FORD unit, HBA-BB1
Engine - Power Steering Pump, 1966 Galaxie Mustang Ford PS Pump, Remanufactured
Engine - Power Steering Pump, 1967-later type, Remanufactured
Engine - Idler Pulley Bracket (bracket only), AC
Engine - Idler Pulley with Built In Bracket, AC
Engine - Pulley, Power Steering Pump
Engine - Pulley, Water Pump, 1-Groove
Engine - Pulley, Water Pump, 3-Groove
Engine - Pulley, Small Idler
Engine - Oil Filter Bracket, Cobra Jet, hi-vol
Engine - Oil Breather cap, Mr Gasket, NEW
Engine - Throttle Bracket, Bolts to Intake
Engine - Valve Cover Bolts - TrandsAdapt, set, NEW
Engine - Valve Cover Stud Kit, NEW
Engine - Valve Cover Bolts - Auto Krafters set, missing one washer, NEW
Engine - Valve Cover Set, 1966 Galaxie XL 7-Litre Mustang Ford GT Chrome, NICE
Engine - Valve Cover - single, NEW (non-GT type)
Engine - Windage Tray ($75.00) - C9ZZ-6687-A // C8AX-6687-A - Originally installed on all 428 CJ and 428 SCJs, also fits 352, 390, 428 Ford FE motors. Instant 7HP gain
Fuel - Sending Unit 5/16s, with Brass Float (almost new) 1965-66 Galaxie, has less 100 miles (switched to 3/8 fuel line)
Fuel - Sending Unit 5/16s, USED
Fuel - Dual Feed Holley DP Carburetor fuel line, NEW though bent
Fuel - Carburetor Spacer, Moroso Phenolic 1-in, NEW
Interior - Accelerator Pedal and Arm
Interior - Automatic Disc Brake Pedal Emblems and Pedal Frame, 1965-67 Galaxie with Automatic
Interior - Door Armrest Base and Pad Set
Interior - Door Ashtray Receptacle Cover (armrest), NEAR NOS
Interior - Door Ashtray Receptacle Covers (armrest), Lot of 3
Interior - Door Ashtray Receptacles (armrest) - Lot of 8
Interior - Door Handles, Inner, Brushed Type, Lot of 5
Interior - Door Handles, Inner, Brushed Type, Set of 2
Interior - Door Handles, Inner, non-Brushed Type (1965?), Set of 2
Interior - Door Jamb Light Switches, pair, NEW
Interior - Door Trim Moulding for Carpet, Pair
Interior - Front Door Courtesy Light Lenses & Bezels - Pot Metal 1966 Ford Galaxie Mustang
Interior - Front Door Courtesy Lamp Housing (goes inside door), One
Interior - Front Door Courtesy Lamp Lenses, Red & White, set of 4
Interior - Front Door Window Regulators, pair
Interior - Rear Quarter Window Regulators, pair
Interior - Rear Quarter Window Regulators, pair PLUS Extras
Interior - Kick Panel, RH Side, supposedly NOS
Interior - Mirror, Windshield, 1967
Interior - Parking Brake Assembly, with new pad
Interior - Parking Brake Release Handle
Interior - Turn Signal Cam Kit, NEW
Interior - Turn Signal Wiring Harness, USED
Interior - Package Tray trim (goes on each side of rear seat) 1965-66 Ford Galaxie
Interior - Package Tray Emblem, 1965-66
Interior - Package Tray, 1965 Galaxie C5AZ-46668
Interior - Sun Visor Bracket NOS 1965-66 Galaxie
Interior - Sun Visors, Black, nice 1965-66 Galaxie
Interior - Sun Visors, Aqua colored 1965-66 Galaxie
Interior - Step Plates 1965-66 Galaxie Fastback
Interior - Vent Control knobs & assemblies 1965-66 Ford Galaxie
Interior - Vent Control knobs & assemblies, 1967 Galaxie
Interior - Window Trim, Complete Set
Interior Dash - Cigarette Lighter & Filament, good
Interior Dash - Cigarette Lighter & Filament, NICE
Interior Dash - Ashtray Receptacle, dash 1965-66 BLACK
Interior Dash - Emblem, Galaxie 500 for Glovebox
Interior Dash - Flasher Switch
Interior Dash - Fuel Gauge
Interior Dash - Fuel Gauge, possibly NOS
Interior Dash - Glovebox Door, black
Interior Dash - Glovebox Door, green
Interior Dash - Ignition Key Bezel
Interior Dash - Ignition Switch, NEW
Interior Dash - Ignition-Door Lock set
Interior Dash - Headlight Knob
Interior Dash - Headlight Switch, NEW
Interior Dash - Heater Control Switch
Interior Dash - Heater Control Assembly, Integral AC Car
Interior Dash - Radio Fader Control Switch, RARE
Interior Dash - Radio Knobs, NOS
Interior Dash - Radio Knobs, NICE
Interior Dash - Instrument Panel Voltage Regulator
Interior Dash - Instrument Panel Wood Appliques and Pieces
Interior Dash - Red Warning Light, Ford Type, mounts to underdash bezel
Interior Dash - Speedometer
Interior Dash - Steering Column Bezel, (wraps around column under dash) - METAL TYPE
Interior Dash - Steering Column Bezel, (wraps around column under dash) - PLASTIC TYPE
Interior Dash - Steering Column, Support Brace (white)
Interior Dash - Steering Wheel, Ford 3-spoke woodgrain
Interior Dash - Underdash Bezel, Woodgrain, 2-Piece Set for AC car (aluminum piece that runs length of dash)
Interior Dash - Underdash Bezel, Woodgrain, 2-Piece Set for NON-AC car (aluminum piece that runs length of dash)
Interior Dash - Underdash Bezel, non-Woodgrain, 1-Piece Set (aluminum piece that runs length of dash)
Interior Dash - Underdash Bezel, non-Woodgrain, 2-Piece Set (aluminum piece that runs length of dash)
Interior Gauge - Bracket, 2-hole, USED, LARGER 2 5-8 TYPE ALUMINUM
Interior Gauge - Bracket, 2-hole, NEW
Interior Gauge - Stewart Warner 2 1/4" set with Broken Temp unit
Interior Gauge - Stewart Warner 2 5/8” set with Broken Temp unit
Interior Gauge - Stewart Warner 80 PSI Oil
Interior Gauge - Stewart Warner Oil Pressure, NEW
Interior Gauge - Stewart Warner Water Temp, NEW
Interior Gauge - Sun Super Tach II
Interior Seat - Seat Hardware, Buckets, HARDWARE LOT
Interior Seat - Seat Trim, Buckets, Back Panels (solid aluminum trim on back of seat), T-Bird Type
Interior Seat - Seat Trim, Bench Seat, Lower Trim
Interior Seat - Seat Trim, Buckets, around Seat Back Edges
Interior Seat - Seat Trim, Buckets, Corners, Set no.1, (6-7 of 10)
Interior Seat - Seat Trim, Buckets, Corners, Set no.2, (5 of 10)
Interior Seat - Seat Trim, Buckets, Lower Trim
Heating/Cooling/AC - Heater Resistor Assembly - C5AZ-18591-A 1966 Ford Galaxie non-AC, NOS
Heating/Cooling/AC - Heater Core 1966 Galaxie non-AC, needs simple solder fix, has less than 100 miles
Heating/Cooling/AC - Heater Hose Inlet Pipe on Water Pump
Heating/Cooling/AC - Heater Hose Outlet Pipe on Manifold
Heating/Cooling/AC - Witek Hose Clamps C1AZ-8287 (9 pcs) 1966 Ford, NEW
Heating/Cooling/AC - Upper Radiator Support Seals 1963-67 Galaxie, NEW
Heating/Cooling/AC - Fan - Clutch, NEW
Heating/Cooling/AC - Fan - Shroud, Crites Type, NEW
Heating/Cooling/AC - Fan - Shroud, Modified with extra metal shielding around fan
Seal/Rubber/Bushing - Rear Suspension Bushings, NEW
Seal/Rubber/Bushing - Window Felt Seals C5AZ-20934 & C5AZ-20935 1965-66 Galaxie, NEW
Seal/Rubber/Bushing - Cowl Seal kit, NEW
Seal/Rubber/Bushing - Vertical Window Seal C5AZ-6330146 1966 Galaxie, NEW
Seal/Rubber/Bushing - Antenna gasket 1965-66 Galaxie & other models
Seal/Rubber/Bushing - Body Mount set, NEW but incomplete
Seal/Rubber/Bushing - Body Plugs, 1 inch, NEW
Transmission - 1966 Ford Galaxie Mustang Cobra etc Trans Boot, NEW
Transmission - 1965-66 Galaxie 4-speed console top plate assembly, aftermarket, NEW
Transmission - Toploader 4-speed Shifter Lever, FORD Type, NICE
Transmission - Toploader 4-speed Shifter Lever Boot, Factory FORD Type
Transmission - 1965-66 Galaxie 4-speed transmission mount, NEW
Trunk - Anti Squeak-Rattle Sleeve - No1 NEW
Trunk - Anti Squeak-Rattle Sleeve - No2 NEW
Trunk - Latch Assembly, factory Ford type
Trunk - Latch Assembly, NEW
Trunk - Light Harness & Light Bracket
Trunk - Hold Down Spring, RARE, NOS
Trunk - Jack Hook, Adjustable Type, RARE, NOS
Trunk - Spare Tire Hold Down - T-shape NOS
Trunk - Spare Tire Hold Down - J-type NEW
Wheels - Hubcaps - set of 2
Wheels - Front Bearing Dust Caps, set, NEW
Wipers - transmission Clip Ford C5ZZ-17531-A, NEW
Wipers - 2-speed Wiper Switch
Wipers - 2-speed Wiper Switch, NOS
Wipers - Motor, 1-Speed with base, CLEAN
Wipers - Motor, 1-Speed, no mounting base
Wipers - Motor, 1-Speed, old and dirty
Wipers - Motor, 2-speed
Wipers - Wiper Arms, Trico, NEW, 1965-66 Ford Galaxie
Wipers - Wiper Arms, Original Equipment FORD, 1965-66 Ford Galaxie
Wipers - Regulators and Internal Arm, set
Wipers - Washer Bag, NEW
Interested in parts. Email me @ [email protected]Hey gang - I have a bunch of parts leftover from my years long restoration, many which were accumulated since 1995. All parts are used unless otherwise noted. If you’re interested in anything, make an offer via private message. I have pics of all which I can send you, be sure to include your email address.
Thanks - Roger
I sent an email to your address as listed. Looking for 66 Custom 500 parts.Interested in parts. Email me @ [email protected]
