1965 2dr restoration
14293 Views 202 Replies 20 Participants Last post by  Touring919
Going to try to keep an index of the high points on this initial post
Page 1&2: intoruction, disassembly, rust repair of roof, floor, trunk and some misc areas.
Page 3&4: frame and suspension restore and engine tear down.
Page 5: quarter replacements and axle rebuild.
Page 6: third brake light design and performance drum brakes and vintage air mounting method
Page 7: three point seatbelt install how too.
Page 8/9: Paint work
Well I have a bit of a head start now. 250hrs worth! So I'll start sharing my progress. The plan will be to keep this thread going until it's done. Which has a long way to go.
Surfing the webs I was snagged in an eBay trap. Found a unicorn of a galaxie and couldn't resist. Saw there was an hour left with no bids so I got the guys contact and kept in touch after the auction ended. He received no bids! Can't imagine why.
Car Wheel Tire Land vehicle Vehicle
Wheel Motor vehicle Hood Vehicle Automotive tire
See less See more
2
  • Like
Reactions: 2
181 - 200 of 203 Posts
Convertible mounts are very different at the front. And yes the one you show should be bolted.
Some small progress this week. Got the hardware all coated with por15.
Eyewear Sunglasses Goggles Tool Personal protective equipment
mid you look close two of the pad pieces look different. I had to make some new ones using some existing body mount washers and the shank of some rusted body mount bolts.
Gas Water Wood Metal Plumbing
cut the shanks from this already cut bolt that was seized to the original nut. Ground clean the old washer and they fit like a glove.
Automotive tire Tire Wood Wheel Tread
run a bead around the top
Wood Gas Machine Auto part Automotive wheel system
then grind off the excess so it is flat. Fits the rubber isolators perfect and is same dimensions as the old pads. Except I left the shaft a little longer. It is a thru hole so no harm there.
Saw Automotive tire Pneumatic tool Wood Drill
now I just need to find a two post lift or several dead lifters to set this big body back on the frame.
I could use my cherry picker but I’m not sure I want to screw around with that balancing act. that requires a sturdy beam through the roof centered on the CG so it balances. One person jacking while another helps balance and align. Probably easier and definitely less risky to transport to a 2 post. Yes I am thinking out loud right now.
See less See more
5
  • Like
Reactions: 1
Not a big update on the way of pictures but it is a huge milestone. Got the body back on the frame.
Wheel Tire Vehicle Car Hood
I elected to go the two post route. Finally had a nice day to work with. 60 and sunny.
have another distracting in the shop so things are moving slow on the galaxie. Still making weekly progress so don’t worry folks. I’m still chipping away at it and will be back to full focus in a couple weeks.
The distraction of the month. It’s getting a primer black paint job. “Quickly” so its owner can hit the track this summer. Currently all the panels are in dynacorn black.
Tire Wheel Car Vehicle Automotive tire
See less See more
2
  • Like
Reactions: 1
Wow time flies when grass starts growing! I’ve been working on a couple things at once with slow progress. Finished the Chevy two and then came yard work. I’m hoarding engine updates until it is actually done. Big surprise I’m waiting on some parts.
Here is a small but crucial update. I did a couple spray outs to confirm my color choices.
wimbledon white and Washington blue. The white is a 60s color option and the blue comes from around 1935. I’ll be doing a two tone paint.
Once I do some small shop updates to improve air filtration and air line updates I’ll be ready to spray. I’ve been hesitant but with these spray outs I feel good about my choices.
Synthetic rubber Tread Wood Automotive tire Tints and shades
See less See more
  • Like
Reactions: 2
I finally quit being indecisive about my seats. Decided to go with modern buckets despite the fact I love benches. I plan to use this for a variety of vehicle discipline and a bench seat is more of a single discipline capable seat.
So I went with a set of corbeu seats to give some lateral support and long drive lumbar and headrest support. And not have the seat back flop forward anytime I hit the brakes hard.
So the bench seat mount holes are not enough. And the cross brace is lacking for a bucket set up. This would require welding. Wanted to finish this before painting. Had to get on this quick. I raided the kids craft supplies and
Hood Urban design Material property Landscape Flooring
had them help cut out a template and then transfer that to 16g steel.
Added section of square stock to add some additional stiffness
Sleeve Wood Khaki Bag Beige
Then it is stitch welded into place.
Wood Automotive tire Ceiling Space Machine
See less See more
3
  • Like
Reactions: 1
The rails from the after market seats are longer than the oem seat. I didn’t like the idea of having the rear quarter of the rail cantilevered off the back of the cross braces. I extended the mounting area using .125" thick steel strips.
Wood Bumper Gas Automotive exterior Machine
I used the rail to mark hole distances. Simple and way more reliable than my tape measuring skills. I used a washer to trace a nice circle for the bolt holes. In these situations I find my plasma cutter is way faster than my dull drill bits. This is why a circle is drawn instead of a dot with a center punch.
Once the holes were “drilled” they were ready to simply lay into place and get welded. Under the rear hole is a threaded bushing to provide support as well as a “nut”. These seats are not going to move around as body weight is shifted!
Wood Engineering Auto part Metal Font
I’ll brush on some por15 for rust prevention.
See less See more
2
Is that the actual location for the toploader shifter to come through the floor?! I have to cut mine out soon for my conversion and was wondering just how off-centered it was. And based on the location of the shifter mechanism on the toploader I just rebuilt, I was starting to think it was quite a bit off to the side (as your pic shows).
I have a three speed and will use a universal mounting system from hurst. So that puts the shifter a ways off to the left. No way a factory console would work with this set up. A factory shifter for a four speed would closer to center.
  • Like
Reactions: 1
It is official. Cooler has started to get laid down.
Vehicle cover Tire Wheel Vehicle Motor vehicle
Made a bank of filters I can jamb between the sliding doors. Very nice to have as it helps to diffuse the incoming air as well as filter it. All the “blue” areas are masked. Roof has been sanded with 400 grit.
Vehicle cover Tire Automotive lighting Automotive tire Hood
Laid down the Wimbledon white. And the clear went on very nice. Should need very minimal wet sanding to just get the small dirt bumps sanded flat.
no orange peel here.
Motor vehicle Hood Automotive lighting Automotive design Car
Contrast this pic of the passenger side roof corner with where it started on page one!
Then there is this mother f&@$er
Wood Flooring Window Floor Automotive exterior
Luckily it was so soon after laying down a thick coat the bugger’s tracks self leveled after 30 minutes. Glad I opted for the slow cure hardener.
See less See more
4
  • Like
Reactions: 3
It is blue! But first there was the final sanding. Where I found lots of pin holes and divots. Could have sworn I caught them all but I guess not.
Tire Wheel Vehicle Car Hood
the picture just has the freshly applied spotting puddy in place. Once sanded there is a small red dot about the size of a pin head. Invisible once painted over.
next came the masking. I really don’t like masking. But it is a necessary evil.
Tire Wheel Automotive tire Hood Automotive lighting
everything was sanded with 400 grit. About as fine as one can go without getting wet. Admittedly I never tried dry sanding with 600. Maybe I should. But I’ve never had issues with 400 so why go more if one doesn’t need too. (I have a friend that wet sand with 800 before painting. His paint jobs are well into 5 figures! On cars well into 6 figures, and sometimes 7, so he’s on a different level). Anyway you can see a slight sheen on the primer after taking out the orange peel with 400.
Next came the Washington blue. 4 light coats of blue.
Hood Automotive lighting Automotive tire Bin bag Bumper
Then two good coats of clear.
Automotive tire Bin bag Waste container Automotive exterior Hood
one final pic with all the masking removed
Wheel Tire Car Vehicle Automotive tire
i know. Not the correct cut lines for painting the firewall. Next up are the Hood, trunk lid, fenders and a couple small trim pieces remain. I have to admit I was not happy with my quarter panel fitment. I was worried about how bad the quarters would look with gloss but I’m amazed how well they turned out. I must be getting more picky as my skills improve.
hopefully the last of my engine parts will get here so I can get that painted too!
See less See more
5
  • Like
  • Wow
Reactions: 3
LOVE the color choice now that we see it on the car. Really great choice.
Thanks. I’m really anxious to see it with all the body panels back on. That will be a bit. I won’t put fenders on until after the drivetrain is back in.
anyone know the original color of the door latches? I assume they were anodized so a bit gold? Or were they galvanized so silvery? I am not going to go with original plating but a paint in the ball park would be nice.
My 66 originals were/are silver looking, I think maybe zinc plating?
Aftermarket ones I bought are gold colored.
Yes. Zinc dichromate. I can do them for you if you want to send them.
Automotive lighting Hood Azure Fluid Motor vehicle
See less See more
  • Like
Reactions: 2
Btw is everyone aware that those are NOT Phillips screws holding the striker?
They are Pozi-Driv.
Similar to Phillips but if you use a Phillips driver it’s likely to bugger up the screw.
  • Like
Reactions: 2
Liquid Paint Fluid Personal care Cosmetics
This stuff always looks intriguing as well, but I don't love the idea of it on strikers/latches. Since those metal parts bang into each other all the time, any paint is bound to chip.
I found a few more pics:
Finger Wood Household hardware Thumb Auto part
Hand Natural material Finger Creative arts Gas
Azure Material property Natural material Electric blue Tints and shades
Finger Electric blue Circle Natural material Jewellery
See less See more
5
  • Like
Reactions: 1
Wow that looks good. I may have to take you up on your offer jazz. I’ll send a pm.
I was not aware those screw heads were not Philips. I had to extract mine. I assume there are replacements available since they are likely common to mustangs.
  • Like
Reactions: 1
I’d be happy to do it. Shouldn’t take long at all.
Here’s a good source for the mounting screws and driver bit:
  • Like
Reactions: 1
We have good people on here. Just wanted to say that (y)
  • Like
Reactions: 1
Son of a poopoo! Was putting kids to bed and it just got me. The fuel door is still burried on a shelf somewhere. I have to get cracking on that in order to finish this paint job on Monday!
Good thing I’m mr mom for the week and don’t have time to paint (but have some time to think). I would have been “all done” and came across the rusty fuel door months from now. Much more colorful language would have been used if that occurred.
  • Like
Reactions: 1
