$h!t. What you see below is a pick of my partially assembled front suspension. Observent folks will note the lower ball joint is about an inch behind the upper. Not good.
So I saw before that the passenger side frame "horn" ahead of the engine cross member was not perfect. But best I could tell everything was plenty straight enough. Core support mount off location by 1/16 or so. No biggie. I was wrong.
Looking with a more critical eye it became obvious the core support cross member should be straight. Mine was not.
The driver side was more or less in tact. Ball joint locations looked good and one can see in the pic that the appex is the bend it right at the pass side strut mount. No other impact damage visible so seems like the wheel hit a curb. Or ditch an took all the impact.
Good thing a week earlier I decided there was no parts left I could possibly need from my donor car and took it to scrap. Famous last words. I keep telling myself that cars xmember was likely too rusty to use.
