When looking at piecing the various parts for a "ford salvage" disc conversion, a few things made that less desirable and convenient than just buying a Leeds or Wilwood kit off-the-shelf.
For me it was:
- No real pick and pulls around here, and anything there will be rusted and seized at this point (in New England)
- Anything I could find at those places (IF they had the particular Fords I needed), would need extensive refurb or rebuilding (more money in parts to do that)
- If those parts turned out to be unsalvageable, I'm looking at digging for more or scrapping everything I found and going aftermarket anyway
- If you find those parts online, they are hideously expensive (for no reason, imo)
- You need new rotors for anything you build. Using a rusty rotor from an unknown car sitting in a field is an absolute no-no. And the rotors for those older Fords are stupidly expensive, from what I've seen, especially the recommended Lincoln stuff.
- Lastly were possible fitment issues. You may need to play with tie rod length and shape when it's all done to get geometry correct.
So all in all...why not spend the money on a GOOD aftermarket kit that bolts right on? This is opening a few boxes and swapping out parts, usually an afternoon's worth of work if you have everything you need on-hand. I can almost guarantee you it won't be more expensive to go this route after all the receipts are tallied.
Want to stay with "factory parts" doesn't keep the car "period correct" because the car in question didn't come with those other parts on it from the factory. You're still Frankensteining the brakes on it.
Sorry for the rant, I just don't see the benefit in using old parts for brake "upgrades".
