Hey, Noobie here and just picked up the vehicle mentioned in the title, I was wondering if anyone knew off hand the size of the battery. :smile2:
thanks
Matt
I also have a 65 Falcon Futura , but my battery is in the trunk.Not sure of the size. I always go with the biggest battery than will fit in the stock location.Roger
gtaroger what all did it invove relocating the battery I'm considering it because my battery is eat uo with rust? Thanks
It is pretty easy to install in trunk. Summit Racing sells a kit.Use the better grade wire, The small gauge cable will cause problems. I put mine battery in the trunk in about 2 hours. I took my time . You don;t need any custom tools.Drill and a few wrenches. Roger
