I just bought a 1965 Ford Fairlane from a gentlement in Sarasota Florida. It had one owner on the title and that person passed away in January at the age of 95.
most likely sucked up crap from bottom of tank....
and it found its way in to carburetor ....clogging it up....
take apart and clean carb ....
stoping to get gas the carb is leaking down you are get to much gas so the car has to set to start at a stop its doing the same check the float & choke& power valve & gas line at fuel pump the ruber one all of these can do what ur saying don't give up yet good luck
Jason, you have not made a poor investment. Your issue is fairly simple once you find it. The trick is to determine exactly what it is doing (or not doing) when it stalls. Likewise when it does not re-start. Unfortunately, most mechanics are not good at simple diagnostics these days.
While we can guide you though some of the simple stuff to try, and things to look for as clues to the issue - I suggest you check with local car clubs (any brand or type) for recommendations of a good and fair local mechanic that knows non-computer cars like yours. One that knows how to do simple diagnostics.
Do you have any mechanical experience or automotive tools?
