I’m trying to figure out how many inches a 10 bolt rear end is in a 1965 galaxie 500 Ltd 4 door with a 390 automatic 3 speed
Ford's are not referenced by the number of bolts and a full size car should have the 9". If you're lucky there will a tag at one of the studs that will tell you the specs of the rear end, as it was built originally.
