Hey guys, finally had to make a post because I couldn't find the answer on someone else's! I have been researching this question for a bit but can not seem to find someone with the exact issue I am having, and I am certainly not a transmission guy.
1965 Galaxie 500 with the Green Dot Cruise-O-Matic, "rebuilt" a couple years ago before I bought it. It is working absolutely perfectly except for the following issues:
1. The transmission does not like to up-shift on its own in any gear selection, however if I CHANGE the gear (such as Drive to neutral, or Drive to Green Dot) it will then begin operating as it should, shifting up and down throughout the drive with absolutely no issue. However, if I stop somewhere and turn the car off, I will have to repeat this process. This is not a huge deal, but I have gone through every inch of this car and its one of the last items I have not repaired, so i would like to.
2. Likely unrelated, but I am also experiencing a leak from the transmission after sitting, which imagine is the converter backfilling. I plan to replace the rings on the filler and see if there are other leak points.
If you have any ideas they are always welcome!
