I'm having issues with my 1965 gas tank, it is leaking, rusty inside, etc. I want to just replace the tank and I found a kit on eBay for a 1966 tank, sending unit, lock ring, filler neck seal, and straps. I've looks on several other posts and I've seen a few different things on this. My main question is will the 66 tank just bolt straight into the 65'? I know the 66 tank is bigger so it will hang down a little lower but that shouldn't be a huge issue. Like is the connection for the fuel gauge the same? Does the filler neck from the 65 work in the 66 tank? Any information would be helpful. Thanks!
