was on a dirt road and high-centered it hit some kind of rock or something ripped one of the transmission coolant lines on Lost transmission fluid crawled under there put the line back together and proceeded to drive home about two and a half miles with the transmission slipping..Hisense change the transmission fluid filter and Gasket and replace the fluid on the steering column Park reverse and neutral go in really easy and when it go to put it in any forward gears it feels like I have to force the column shifter it's real type bound up feeling I have no forward drive gears I found a cracked line vacuum line to the little modulator valve on the transmission and replaced line still no change please help I am stuck in Oregon and need some kind of halfway simple fix to get to Southern California is that possible thank you..
