I have a 1966 352 short block, it appears to be a virgin. Block casting number is C6ME- (no suffix) Casting date of 6D23(Apr. 23, 1966) Short block includes the front cover, balancer/single sieve pulley combination and snout spacer. I was able to remove 1 piston with no problems. Block has nearly no ridge. The rod bearings are FORD with C5AE-A part numbers on them. The 1 piston I removed has 352 on the sides, rods are C1AE-A. I have pictures and can send them.
Pick up price is $200.00 Note I am located on Camano Island WA, about an hour north of Bellevue WA, No ferry boat ride needed.
I have removed the oil pan since this picture was taken.
As it sits today.
I will include the oil pan if wanted, I feel this is a good core for rebuilding. I have a couple set of heads, I think they are C6AE-A but have to verify. Heads will be $100. per pair.
Thanks, contact Neal at [email protected](dot)com
