341 - 360 of 373 Posts
Discussion Starter · #341 ·
Hi,
this is JollyDodger, DesertXL's spouse.
I learned much from the first seat, so for the second seat, it was easier to inlay the metal supports with drawn lines. If this is of help to anyone, here are the numbers for the seat bottom:
Burlap size = 20" x 25"
Number of rods = 16
Distance between rods = 15/16" = 0.9375"
Distance from 1st rod to last rod = 16" approx.
Rectangle Wood Font Net Composite material
Product Rectangle Textile Beige Sleeve
Discussion Starter · #342 ·
That riser is specific between 2 and 4 door because the 4 door has about 3 inches more rear seat let room. The back flange of the riser is in the same spot as the 4 door and 2 Dr. But the 2dr is deeper towards the front of the car. You'll note the rear seat back bolts directly to the floor but the 2dr seat back bolts to brackets that are about 3 inches forward of the floor bolt hole location of the 4dr seat back.
The 2dr seats are roughly 3 inches forward relative to the floor pan which is common between 2 and 4 Dr. This is to give head room for back seat on the fast back cars.
Here is a question. Anyone with a 2 door sedan that cares to look if they have a 2dr or 4dr rear seat mount location. With the formal roof line of the 2dr sedan there is a chance they have the 4dr layout. Confusingly that may mean what I have been referring to as the 2dr riser and seats may actually be fastback specific.
All this also means the rear seats are specific between 2dr (fastback?) and 4dr. The 2dr rear seat back is thicker at the top. And the lower seat has its latching wire mesh made different.
Hello Touring919,
Thank you for that note. I did notice differences between our '66 4 door hardtop LTD and and this '66 2 door hardtop.
Cheers
Discussion Starter · #343 ·
DesertXL you are truly a jack of all trades and a master of all.
It is rare to find someone that does body and engine work. You throw in automatics. HVAC. EFI. Interior. Amazing. All of It at a high level. I will be referencing your work for the body mounts on my car. Great info.
Hello touring 919,
Thank you that is very kind of you say that. I feel more like that scene from Raiders of the Lost Ark, when Indiana is asked, how are you going to do that? of which he replies, I don't know I'm making this up as I go along.
I'm more adept in the laboratory than in the workshop.
You are making some progress in your adventure with your 1965 I must say. It's loads of work and a pain when finding replacement parts, especially body panels is getting very hard to come by. I've been collecting parts for several years and have had more parts cars than I care to remember just to get these three 3rd gen full size Fords back on the road and it's still a quagmire at times.
Cheers
Discussion Starter · #344 ·
Front Seats Restoration Part 4
We put the seat bottom in the sun room to help relax the covering.
Next up is the seat back.
Making the burlap reinforced back.
This piece covers the back springs.
This piece covers the top of the seat.
The part number tags are attached.
The back burlap is attached along with the long vertical rods.
The top burlap sections gets attached.
Continued in next post.
Discussion Starter · #345 ·
Front Seats Restoration Part 5
Next is to remove the decorative emblem backing plate from the old seat.
New emblem.
Installed.
The original retainers are bigger than the reproductions, so I used the originals.
New foam back.
Now the top side of the seat back foam has grooves but these are for 1965 seats. So we'll need to add channels for the '66 width.
You can see the original wider channels in the old seat foam. A brand new sharp box cutter knife worked well.
These old rods in the old seat cover need to be installed in the new seat covers. Now these rods were hog ringed to the vertical rods through the old foam. The old foam is very thin and reinforced to allow the hog ring to penetrate, however the new foam isn't so forgiving and not reinforced so we didn't take it to thin. This however doesn't let us hog ring it. So my better half came up with an ingenious alternative to a hog ring.
She used heavy gauge safety wire to make effectively a long hog ring.
She pushed the heavy stiff safety wire through around the rod in the seat cover, through the foam and around the vertical rods affixed to the seat back springs.
Discussion Starter · #346 ·
Front Seats Restoration Part 6
The wire was twisted then cut and bent over. Both rows were done on the seat back, then the seat cover was pulled over the rest of the frame and hog ringed.
It really takes two people to pull this on tight and hog ring it.
The wire used is 0.051" stainless steel safety wire.
Next is to assemble the seat back panel.
This is the backside and the old colour still sprayed with some samples of paint we were experimenting with.
The outer bright work trim slides down and lips on the edge of the seat back panel. It's screwed in first then clipped.
Clip retains the inner portion of bright work to the steel window.
Completed seat back panel.
The next portion is to bend down the little spikes on the back of the seat frame holding the edge of the cover on.
Discussion Starter · #347 ·
Front Seats Restoration Part 7
The seat back is ready for the back panel.
Next is to locate the screw holes for the retainer brackets.
Installed.
The top slides down the retainer clips and then lips over the bottom and is screwed in.
Finally coming together. That back panel is pretty taught against the seat material and frame for just hooks holding the top in.
The lower trim pieces go on next.
The colour temperature of the soft white bulbs in the house play havoc with the true colour so I intermix flash shots for a more realistic colour rendering index.
The back seat rest pegs are installed. The seat back is done for the moment.
Discussion Starter · #348 ·
Front Seats Restoration Part 8
Focusing on the seat bottoms we cut the reliefs for the fulcrum rods protruding from the sides.
The piece of metal lower trim can go on next.
Next piece is the rear centre back trim.
The other lower side trim panel gets the bright work attached to it. There is only bright work on one side because the side facing the centre floor console doesn't get any.
For some reason the bright work here didn't have any clips, just screws.
The bottom is ready to have the back attached.
This takes two people. You have to pull the back lower arms apart to get it over the fulcrum rods. I'm surprised they did not use shoulder bolts for this.
Continued in the next post.
Discussion Starter · #349 ·
Front Seats Restoration Part 9
I did use some clear silicone grease with PTFE in it for the fulcrum.
The rolls pins to keep the seat arms from coming off, although from the amount of pressure it took to spread the arms I would find that unlikely.
The decorative trim snaps on next.
The seat tracks can go on next.
The seat tracks were greased with the same clear silicone with PTFE so it doesn't stain anything should it touch the seat cover or paint work.
The lower plastic trim goes on next.
Discussion Starter · #350 ·
Front Seats Restoration Part 10
The other side trim.
The last bits are the seat back peg rest pads to go on.
Now the seat back can rest on the seat bottom.
This is the seat adjustment knob and these seem to be a snap together forever variety as you pretty much have to mangle it to get it off. I see Scott Drake remakes these, but I rather have a shiny metallic piece with a set screw. I shall have to see what I can find for this.
Aside from the knob this front seat bucket is done.
I've never seen a small bucket seat with so much trim and other pieces. This one bucket seat took many solid man hours of labour to refurbish. One more to go.
More to come.
Cheers
Discussion Starter · #353 ·
General Body Repair and Modification
I know this thread jumps around a bit however whilst some projects are in process, others are tackled to save time.
In this portion I am tackling some general body problems.
This is the transmission tunnel hump and there's the hole for the plug to adjust the band on the Borg Warner automatic transmission equipped cars. Also since this was a dealer installed under dash air conditioning car, others have drilled holes for the condensate drain and rear mounting brace. All this needs to be filled in.
This car body will now be mated to a chassis that utilizes a fully rollerized C6 so this isn't needed as the C6 band adjustment is on the other side and down lower.
I could have just used a rubber plug for these holes but since the large factory centre console is going over this I didn't want to take a chance on a plug falling apart or falling out of the hole and having water ingress under the carpet.
It's just a quick patch, since it's all hidden I'm not too concerned with how it looks under sound deadener and a centre console. It's water tight and that's all that counts.
This was another problem and unfortunately i didn't take a before picture. But there was a stamping tear in the roof. It was covered originally by seam sealer. So it was welded shut.
This the passenger side front lower rocker and it has two noticeable dents where the lower rivets go to hold the rocker retainers. These need to be pulled back out. They do not have to be 100% perfect because it's getting rocker trim, but the metal must be moved so the plastic clip doesn't break whilst installing it nor distort it to prevent it holding the rocker trim on properly.
Close up of one dent.
And the other. They both are pushed in a fair amount.
The Elenco dent puller is perfect for this type of work. For those unfamiliar with this, it has the temporary welded in tip that fuses the wand to the metal with a built in slide hammer. Once you move the metal, you simply give the wand a twist and it separates from the metal you were attached to pretty cleanly. Makes pulling metal very very easy and fast. Plus this machine has attachments where for large areas you can spot weld cheap unplated washers and use them to pull in multiple places. It also has an attachment to weld on the trim pegs around windscreens and rear windows. I've already used this feature.
Took longer to set up the machine and plug it in that it did to repair this area.
As for the rest of the body shell really the only places left are the rear quarters once the firewall and cowl are finished.
Next is more work to the firewall and general interior body rust proofing.
Discussion Starter · #354 ·
Firewall Replacement (Conversion to Factory Air Con) and Rust Prevention Part 4
Back to the firewall and cowl.
I removed the door nut plates and scoured the rest of the metal areas inside the drain area to prep for sealing paint.
These are the door nut plates for this side.
Next was the first round of POR 15. This was all brush painted on. The goal here is to get the POR 15 into all the seams to seal them. If paint is in there and covering the steel, then oxygen can't get in.
Next up was using the Eastwood's frame coat with a stray. I find this does a slightly better job of covering steel than POR 15. So any gaps left behind I think this does a pretty good job of sealing. Also I used this in the cabin area to seal all the bare steel left from assembly to stop any further corrosion.
It's a terribly messy thankless job. But it must be done if you want to daily drive these cars and reduce the worry about future rusting.
When I was prepping the interior roof structures for this by blowing them out. The old field smell came right back out again. There didn't seem to be any flotsam in the upper rails but that smell brought back some old memories of this turd. This car body has been in this reduced state for quite some time and that smell was still lingering in the cracks and crevices. This should be the end of this smell in this body shell. There's simply no where else for it to hide anymore.
Just to rehash, this is what this car looked and smelled like (if you had smell-a-vision). It was sitting in a field in an Indian Reservation for decades with a broken drivers side window.
You can plainly see the massive under dash evaporator still in the car.
Between the hot desert sun, occasional rain the rodent motel this was you can imagine the smell of this........not good.
This is such a messy job and I really don't see many people, even shops tackling the seam rust. I always seem to see just a spray of paint over all this with no attention to the fine details. Yuppers it's a mess and it's more work to sand all the drips back out for the final top coat in here but I feel it's worth it to have the hidden layer of protection. You have to keep in mind, only the rocker tunnels and some of the rear panels are galvanized, most of the body is not.
Discussion Starter · #355 ·
Firewall Replacement (Conversion to Factory Air Con) and Rust Prevention Part 5
As you can see everywhere I can I give it a good douching of sealer.
I then gave it another coat of POR 15 in the cowl area favouring heavily the seams.
I'd almost say it's darn near water tight without the seam sealer.
Speaking of which, it will go on next.
Since all this needs time to cure, I decided to start on the HVAC plenums in the interim.
Discussion Starter · #356 ·
HVAC Plenums Part 1.
I want to preface all these dealings with the 3rd gen (1965-1968) factory HVAC system with it's not all that and a bag of chips when compared to the 4th gen (1969-1974) systems. These 3rd gen systems are overly complicated, more difficult to diagnose and you cannot get dehumidified warm-hot air to the windscreen or out the main dash vents.
I'll go into this more later once I really get into the thick of it with this system. I will say this, when properly working the heater works well (as long as your using the 195 stat) and the air conditioner really works well on hot desert days.
There are three separate plenums to these factory HVAC systems. As a side note for heater only cars there are only two plenums.
I'm going to start with the heater core plenum, since it's the smallest and easiest to manage.
I have three to chose from and yes I did stock up on these now rare and expensive parts. As these cars age the plastics just become increasingly embrittled. All three of these are from Southwest cars. I'll go through these and pick the best parts to make one good one for this gal 500 XL.
Even being a Southwest car doesn't preclude corrosion problems.
And this plastic housing is just falling apart as you touch it. So this one can go instantly back as I'm not going to bother with it. I tackle the remaining two and see what's what when disassembled.
This is the original one off this gal 500 XL.
And this one I pulled from a car in the junkyard. Actually we took the entire HVAC system off it.
When you strip the foam off, you'll find more hidden corrosion and it goes downhill from there.
That date indicates July 13, 1964. Tis original.
This is a good time to discuss heater cores for these 3rd gen HVAC systems.
There are two different one for factory HVAC (air conditioned) cars. The cores are physically the same, only one has the same 5/8" tubing for inlet and outlet and the other has 5/8" and 3/4" tubing. I chose to use the core with the same 5/8" tubing because I just bought a big roll of 5/8" black silicon heater hose and it does the entire car.
I have seen aluminum ones offered but they look smaller and probably a nightmare to get to seal. Not less forgetting brass/copper cores will simply last longer from a corrosion perspective.
Fortunately I bought all the HVAC stuff for all three old Fords we have ('66 LTD, '66 gal 500 XL and the '68 XL) a long while back. I'm glad I did, because now what you can find available it 2-4 times the original price. It's all insane if you ask me.
Back to the plastic housings. The plastics are dying. I walnut blasted these and in some areas the plastic was just sloughing off. This can still be saved, but this means sealing and strengthening what's left.
Discussion Starter · #357 ·
HVAC Plenums Part 2
It may be hard to see, but the plastic is heavily pitted and in one area went right through.
The other plenum was in much better shape but still had areas where the plastic just came off in droves.
The best solution I've found to date is simply build them back up and seal them with fiberglass resin. It's a messy, stinky job, but does seem to work and will prolong the life of these plastics.
Here you can see just how pitted that one plenum was. That will need several brushed on layers.
The heater core retainer plates didn't fare much better when stripped. One has a small hole and the other, well, you can see for yourself.
After some cutting, welding in patch steel and giving it a quick grind (not going for looks just structural integrity), these are ready for paint.
Here's the better of the two plenums after a couple rounds of fiberglass resin inside and out and test fitting for a sanity check.
A couple of years ago I would normally just toss the old parts, even if they were still OK. Now with the parts shortage and poor quality of replacement parts I will keep the old cores as spares. However I will clean them out first. I gave each a good flush with the hose, then boiled some hot vinegar on the stove and filled each one and let them set for 20 minutes. Then flushed again. Oh my the crap the came out.
This was after several flushes after mild acetic acid treatment. One was still spewing rust from what I can only imagine is the engine block.
Discussion Starter · #358 ·
HVAC Plenums Part 3.
Time to assemble the heater core plenum.
Bolted the tube strain stop back on.
Reused the old foam on the new core. It still was in serviceable condition.
I used some generic foam to keep pressure on the core and keep it from moving. Just have to get creative with some of this.
Everything is sealed and snug.
Now this isn't pretty, but it is functional and you're not going to see it when it's installed. This is EPDM foam seal and it's 3/4" tall. There is a place that sells new foam for these. That place is Detroit Muscle technologies. However,,,,, they list the foam they use in this plenum as 1/2" tall. I have experimented with 1/2" foam and it will not seal all around. You have to use 3/4" tall and here's why; the plenum goes over layered sheet metal on the firewall, the firewall isn't not perfectly flat and nor is this plenum. The stack up of tolerance in some areas will lead to gaps with a thin foam.
This generic foam works really well as I've tested several.
Fitment.
There's no gaps in this.
Here's the other heater core plenum, it could use a few more coats of resin and sanding, but it's strong and going to last. This is just going on the parts car to get it out of my hair and is just a spare.
There's the rest of the HVAC plenums to chose from and refurbish, plus other odds and ends I dug out. I have loads more if need be.
More to come.
Cheers
A guy I just sold bucket seat covers to a while back told me his buddy who does upholstery and helped him out did this he told me. Excellent idea! Even when I carved my own foam for seat 1 it was very difficult to do this part, especially if a whimp like me. The other side I bought the replacement foam and also wished I had done some whittling or something so it wasn't so thick! I am not a thin person and could barely get my legs under the steering wheel so I swapped it to the passenger side and my son who is 6' 3" can look over the windshield almost. But I don't have the ambition to take it all apart again. Getting to those listing rods was a nightmare doing it as they did but I got it but doing it your way on the back seat! I'm getting to my rear seat in the next week or so hopefully, if I don't run out of time for trip, then it's foam and mexican blankets til i return! I just don't have the strength in my hands to do it.
On the reinforcement wires, I always assumed those were to keep the foam and burlap from bunching up between springs and to equalize the pressure on the springs. Don't know if that's the actual purpose but in my mind it is. Since I'm not doing it to look or be correct as original I am going to use burlap or maybe another heavy fabric I have and bird wire/rabbit, wire netting, whatever it may be called and attaching it to the springs here and there to hold it in place. May be hillbilly but rarely does anyone sit in back and if they do it's only for a few laps of a street cruise. It will still beat the bare springs, vinyl and shower board I have there now for the seat bottom. Plus if I EVER get mice they will have to go around to get in the seat and not through the bottom. :D
Excellent write up!!! I think I might pin your thread to the top as there is a ton of useful info there for anyone that is new that comes in later in the future and is looking for some of this. They won't have to search and they can get referred to this thread easily also. Not to mention some of this will pertain to other years also in a way.
Thanks for taking the time to document all this! I know it takes work to do all this documentation!
Discussion Starter · #360 ·
Hello ShotRod64,
You know sometimes I can be so obtuse, I didn't even realize till your post here that the bucket seats for the '65/'66 XL/7 Litre package are carry overs from late second gen full size Fords. Then the idea was cemented this last Friday as we went to a local car meet and there was a '64 galaxie 500 XL with the seats I could see in person. The material pattern is different and I think the centre back aluminum beauty trim changed with a washboard effect by '66 but otherwise those are the same seats.
The funny thing I noticed about these seats is that they are actually more comfortable than the bucket seats in both of our '68 XL's. Obviously I couldn't make a determination till after one was refurbished as our '66 bucket seats were just destroyed in that old Texas car. Plus I wouldn't have thought such a thin seat could be comfortable and by contrast the '68 factory bucket seats are very thick and it gives the illusion of more comfort.
Now for the bottom seat portion of the '66 buckets we did not pull the centre down with those listing rods and left it more convex in shape just because we felt it would be more comfortable. Maybe that helped, maybe it hindered. Dunno, it was just our decision to try it that way and deviate a bit from the factory design.
As a side note thank you for pinning this post. I hope others can find it useful, there is much in here. Plus it makes it easier for me to find when I update it :)
Cheers
