21 - 22 of 22 Posts
Discussion Starter #21
The shaft of the motor was alright, it was the opposite end that is stuck in the bearing. The housing with the two wires should have been pulled off to expose the armature and the brush assembly.When I pulled the housing the armature came with the housing, this caused the brush mounting plate to break. Is the bearing in the housing with the bulge held in with some type of clips.
Greg
I believe the bearings are pressed into the housing - being held in a plastic support.
21 - 22 of 22 Posts
