Here are a few items that are interchangeable from 1966-1970 Falcons.
66-70 fenders all 'technically' bolt up, but have small differences that will need to be remedied to be "correct".
66-67 doors interchange, 68-70 doors interchange. The doors themselves WILL bolt up, but the crank positioning through the trim panels etc is different.
68-70 grilles are all the same (Im almost certain), 66 and 67 are year specific.
66 and 67 taillights do interchange, but have a different look to them. OK as long as you dont mind it not having an authentic look, but the bolt up and bulbs are the same.68-70 taillights are all the same (again, Im almost
certain), but not with the 66-67 as they are round and the latter are square.
66-70
glass interchanges.
Hoods interchange, but there is a grille support flange that needs removed for a 66-67, or added for a 68-70. Hood themselves are all the same though.
68-70 dashes are WAY different than the others. 66 and 67 will interchange, but do have a different look to them.
66-70 trunks interchange.
66-70
window trims interchange.
66-70 wheelwell trim does/will interchange, but do tend to get different looks to them.
Get a whole set or dont bother.
66-67 front bumpers are the same.
68-70 front bumpers are the same.
66-70 rear bumpers are the same as far as I know.
1969 Falcon SIDE MARKER BEZELS C9AZ-15A440-A same as MUSTANG, SHELBY, BOSS AND CJ
Handles, latches, and locks will also fit 66/67 Fairlane and Comet, 66-70 Falcon, 68-71 Torino and Montego, 69-70 Cougar.
Headliners for a 1966-1971 Fairlane, Torino, or Comet - fastback, hardtop or sedan will interchange with 68-70 Falcons.
64-76 FORD FALCON/FAIRLANE/TORINO trunk lid seals are all interchangeable.
#6735 POWER STEERING SLAVE CYLINDER FITS;
1967-70 MERCURY COUGAR
1965-69 COMET, MONTEGO
1966-67 MUSTANG
1966-69 FALCON
1966 -69 FAIRLANE, TORINO, RANCHERO
1963-4 FORD GALAXIE
Front shocks 1966-70 FORD FAIRLANE/FALCON; 1975-80 FALCON; 1961-63 THUNDERBIRD; 1960-65 RANCHERO are all the same.
Left and right side
door glass fits in a 1966/67 Ford Fairlane 2 door sedan model 62-A ,62-B. It will also fit in a 1966 to 1970 Falcon 2 door sedan model 62-A ,62-B ,and 62-C Futura.
67 Fairlane Hood hinges are the same for the Comet, Falcon & fairlane from 66 to 69 & to 70 on the Falcon.
If you need a new dashpad , a far cheaper alternative is to use the dashpad and instrument cluster from a 68-69 Fairlane, Torino, or Ranchero. They bolt up correctly and you'll need to cut 2 small slots in the lower dash frame for the heater controls to poke through and some simple remapping of the electrical.
Justin Welling started this list originally and we all can add to it!
