I recently purchased a 67 Ford galaxie 500. and I'm trying to work out all the bugs.The horn just does not work. Looks like previous owner wired it direct and installed a push button on the dash for it to work. I have the steering wheel off now(fixing turn signal switch)Is there anything I should I look for in the column or does the problem lie elsewhere?
Thanks, Dan
The little horn button thing with a spring on it that sticks out of a little hole, maybe it was just bad. If the wires still run through the column you can ground that and should make the horn honk. Also check the wires are still connected to the horn relay that should be near the horns somewhere.
