I have a c-4 and jus looking for a cruiser
Well Lets go from there,
Your C4 will mate to any Windsor engine from 1965 (6bolt bell-housing) -1981 excluding the 351W which was discontinued 1997.
en.wikipedia.org
IF the plan is for performance the C4 can be mod to handle the power plus FORD also makes a C6 which can be bolted to the mentioned Windsor 6bolt pattern. For better Gas mileage the AOD will bolt up and work, but there's what as known as the imbalance factor and will have to replace the 28oz flywheel and harmonic balance to a 50oz.
In this edition of Pit Stop, Tech Editor Marlan Davis has the secret to balancing small-block Fords.
www.hotrod.com
I had perform this same process on my brother-in-law 1967 Mustang HT with his 289. Once the AOD was install with both the 50oz flywheel and harmonic balance, his MPG went from 18MPG Highway to 24MPG and city from 10MPG to 15MPG.
Review Ford AOD Transmission Installation and Swapping Guide at DIY Ford. This is the complete guide for transmission process will work over your need.
www.diyford.com
You can also replace the trans cross-member and drive shaft with the stock C6 units for the Mustang instead.
Cruiser? Please be more specific. Daily driver? Stock? Modify?
What is your limit $$$$?
