Quick and easy question for you guys.
The radio in my 67 doesn't work and I can't seem to trace a reason why it wouldn't I checked under the dash and all the wires seem to be in good order. The Speaker in the dash is wired. The antenna wire seems to go where it needs to, I can only race it to the firewall.
What in the fusebox should be connected in regards to the radio? I have read it just runs off the same fuse as the turn signals, correct?
There are two small square spots on the left looking in that have nothing in them. What are these for? (This is an off topic question, probably not related).
-Frank
-Frank
