i have a 1968 galaxie 500 with stock front disc brakes....yesterday i purchased some rims from summit racing.....the only size i could get with these rims was a 15x8 with a 3.75 inch backspace...placement on the hub without the tires on looks like they will be fine....am i correct in this assumption and if so what size tire would i need?
On my 1968 XL i have 3.75 backspacing on front and 5.5 bacspacing depth of the rim in rear in which case i have 15x10 rears and 15x7 fronts and I am pretty close to the spring in the rear. I also measured bolt pattern if you needed it to confirm for your order and it is 5 on 4.5 as well just in case you needed that. Shipping is crazy expensive! Tire size depends on what ur doing with your application. More info will help!
thanks for your reply....i allready have the rims as i live about 2 miles from summit....they are 15x8 front and back with a 3.75 backspace and a 5x4.5 lug pattern....was thinking of putting some 235 60 r 15 tires on them....will this work?
On the fronts I am running a 235 60/15 and on the rear with air shocks I run a 295/50, the fronts have absolutly no clearance issues and fit really well, in the future I am going to drop the front down on tire sidewall height, I want to lower the front only like an inch or two, I believe I can get that without changing springs, However the rear with stock springs require air shocks to keep the tires from just barely rubbing on the rear quarters, I keep them at about 125psi and never have problems. Good luck with the new rims and tires!
