Pandoras Box - Cooling and electrical, well mostly, continued
Here's another example. The wire for the compressor clutch is about 12" long. In that short span, it's been spliced together twice and has a scotch lock thing attached to it.
Here's the other voltage regulator that was still connected.
That "other" voltage regulator is spliced into the charging harness with the factory non-stick tape. This was done a long, long, long time ago. What's the point of 2 voltage regulators?! I also do not recognize the front case of that alternator. Could be just coincidence. I know there was a 65 amp Leece Neville alternator option, but that's neither the correct alternator case style nor voltage regulator case style.
Back to engine "FUN", err I mean ROT
Oh god, if the rest of the engine looks like this on the inner cooling jackets, no wonder why it has all sorts of problems. There is a thermostat in there, however it's stuck open. So either it's a regular thermostat and it just failed, or it's an all crudded up regular thermostat, or it's a fail safe thermostat locked in the safety position (open). My money is on the crud option.
And this is precisely why I ABHOR aluminum radiators. I have replaced more aluminum radiators for this reason that I ever had to replace brass copper ones. This radiator has more corrosion than the entire car does.
And it's in stereo.... Both lower sides are rotting away.
Oh goody I can't wait to take off the coolant pump, I bet there's all sorts of unpleasant things in there.
I should mention that's not antifreeze, it's some kind of additive that guy used with water. It doesn't smell like antifreeze (glycol) nor feel like it. It feels like water, plus it stinks. Probably is just water with food colouring for all I know.
The adventure continues...
Cheers
Cheers
