1969 351 W Block, Factory Crank and Rods. Windsor Sr. iron heads. Comp cams roller rockers, guide plates, push rods, lifters, and cam. Ford Motorsports valve covers. Aftermarked fasteners.
This engine came out of a friends Cobra replica with less that 8k miles on it. He was having it tuned on a dyno, and it broke a piston at the top ring. The piece went out the exhaust, and did not go into the bottom end. He was going to replace the piston, but went with a stroker crate engine instead. There was no damage to the head or cylinder walls.
$1500.00
$1500.00
