A early fe has 2 bolt pattern, fe motor supports has 3 holes, so mine does, depends on whay year motor . One support hole will line up on motor. Get you a steal plate and make you a bracket to support the motor to fram. If you use 1/2 inch plate your motor will be 1/2 inch higher in body is all. Use common sence in making bracket supports, easy
