I hope I'm posting in the write section... kinda new here.
I have a '69 Mark III that starting running like dog turd all of a sudden. Pulled it out of the garage, it was fine. Started it up to back it back into the garage and with the accelerator pedal halfway down, the car was barely moving and rpm's were very low, almost as if it were flooding, but the exhaust smelled just fine.
I just parked the car and came back to it another day. So first thing I did was pull the plugs. They were all fouled out. The motor is still breaking in so I assume this may be the issue. Replaced all the plugs and fired it up. It started, but still running like crap. Terrible idle. Seems to smooth out a little bit when I give it gas but when it comes back down it idles rough and will eventually stall if I don't feather it a little to keep it running. Exhaust does not smell rich. I even isolated the vacuum system (minus distributor)
So I'm thinking it has to be something ignition-wise. I start at the coil:
Mallory Aftermarket (for breaker-points ignition) Coil: 1.8 ohm primary and 10,800 ohm secondary. Seems to be ok although stock coil is 7,800-8,800 secondary. Most aftermarket coils seem to be on the higher side.
Wires look good, they are basically brand new... 4 years old but less than 1,000 miles on them and were replaced with engine rebuild.
I took the cap off and inspected the points. I can't really tell and don't have much experience with them other than adjusting but the surface looked kind of pitted and also, the contact on the bracket part of the points has a hole in it so I can see through it. Is that normal?? Anyways, I lightly filed them and reset the gap. Started right up but still running like crap.
I'm out of ideas. I'm willing to bet it isn't fuel related but could be wrong.
Any ideas??
Any ideas??
