I have a 1969 Ranchero on the Fairlane 500 chassis. 2dr, column shift. My issue is that in order to start the car it has to be in neutral and sometimes even "wiggle" the shifter within neutral. I used to be able to pull up on the shifter while it was in park but that stopped working and now it's only neutral.
Do I need a new neutral safety switch, is there a way to test or adjust it, or is this something else. I had trouble figuring out reading the other posts.
Any assistance is appreciated.
Steve
Probably time for a new NSS
If the back up lights are incorporated into it, your backups are probably iffy as well.
Might get by with adjusting it (if it is adjustable like GM is).
