Hey Guys,
I just bought a 69 torino formal roof with a 351W and an FMX transmission with a column shift. I'm looking to add a set of headers and was checking Summit Racing's site out. I noticed that there were a couple of decently priced Heddman headers but when I went the application guide it noted that there were no clearance issues with an automatic with a floor shifter but that there were issues with an automatic with a column shifter. Anyone know what the issues are with the column shifter and if they can be worked around?
Thanks for the help!
check the hooker headers, they should fit with column shift. It has to do with the linkage of the column shifter and the rear tubes...
Yeah, the shift linkage is really in the way, and with most long tube headers they will hit the power steering cylinder. I had this happen with the 302 in my 68 torino fastback. If youve got the ambition and the $$$, i'd convert it to a floor shift anyways, much better feel i think. Or get some shorty headers from summit, i think they are fairly priced.
In my '68 Falcon I installed a 351W and FMX (from a '69 Torino) w/Shelby Tri-Y Headers, I also used a B&M Quicksilver Ratchet Shifter. I went with the B&M cause I would run into a hassle with the stock shift linkage.
The only "big" problem that I ran into was getting the shift cable adjusted correctly to match the letters on te floor shift. Still a little off, but I know how to get the shifter to work correctly and a thief wouldn't. When I take it to a shop, they have me drive it up on and off of the rack cause of that.
That was 5 years ago and everything is still working fine.
Good luck with whatever you decide to do.
TJ in Green Bay, Wi
I have hooker comp headers in my 69 fairlane with 351w, they are the cheaper ones (not super comp). I had some small clearance issues on the driver side only, they hit on the firewall between the gas and brake pedal, and a little on lower "frame". I use a floor shift, so don't know about the column shift. The same headers worked fine with my 302 and column shift, but I don't know with the 351w, should be fine though?
What is the part # you used on the 302 column shift. I have the 302 with 3 on the tree standard so I have 2 shifter arms to cear instead of 1. I think these headers might be a good place to start to remedy my clearance problems.
