1971 Lincoln, pwr steer and wipers run off same pump (filled with Type F). When cold all runs perfect. No Leaks.
After 20 mins, pump wines, hi and lo press hoses HOT HOT HOT, fluid bubbles/blows our of filler tube.
Flushed with 3 qts Type F.
Same Prob.
Replaced pump with brand new one.
Same Prob.
When car is cold, all is well.
Any ideas, advice greatly apprec!!!
- Wixomhead
My company had a 93 Taurus that did the same thing after the rack and pinion was replaced. The garage that worked on it put the pressure and return lines on backwards causing the fluid to boil and lots of smoke after only about 10 minutes driving. The pump wound up going bad and the rack blew out all the seals, so they had to replace everything again. It only took about 15 minutes of total driving to cause this, so I doubt it's your problem, but I wanted to point it out in case you recently had the steering worked on.
