Well everyone
I finely got it togather, but when I put it in the dyno all I have is low every detent is low no neutral, no reverse, no drive or second. I have park but I think the paw is the only thing holding it from going into low.
There are some bolt issues that hold down the valve body, but i dont think it would have anything to do with it. the linkage is off cause with the valve body in the trans there is no park detent just sits on top of the lob just enough to engage the paw.
i had good line pressure about 100 or so, at least i think its good and the cooler pressure was around 40 in and 0 out. i have about 8 quarts of Type F. can you guys and gals please shoot me some suggestions. all i could use right now is help. in preveous post i talked about a brass spacer that was taken out of the valve body and cant find where it goes.
i am thinking it is a spacer for the filter under the spring that the tang holds down i dont know and i need some help
thanks all lot for all your info.
