wutsup everyone i came across a 90 lx roller with a carb 302 bolted to a small block c6 for 1550 i got a aftermarket streetrod wire harness ready to run distributor mallory 6al ignition longtubes electric waterpump holley 600cfm carb an a holley blue pump edelbrock performer manifold . i was curious if i was gonna have a problem with the wiring because the original harness didnt come with the car i have a switch panel with a start button an fuel ,water , fan an ignition switches
also what should i do about the vacuum system is there an aftermarket product or should i get one from a junkyard ?
Well... since your engine is carbed, wiring is quire easy. If it hasn't already been removed, you can remove ALL of the harness form the EFI system. It is totally separate from the rest of the wiring for the car. In the remaining wiring in the engine bay you can find the hot wire from the the key. This will fire your distrributor. Other leads for oil pressure and water temp you may want to run yourself to custom gages.
As far as vaccum, I don't quie know why you are worried about it. You can pick up a vaccum source from your intake manifold and run a vaccum line to your vaccum distribution block. That's waht I did on my '89 and everythign works great.
Hey guys,
I have been researching a lot on which mustang motor I want to get as a donor for my 1951 Ford f1. I have decided on an efi 5.0 with MAF, and been leaning heavily to the 89-93 models. My goal has been to find a wrecked car to pull the motor and trans from (1- cheaper, 2- I can't kill...
I traded my falcon I had for an 82 Mustang GT that had a 351w in it. The kid lost bearing messed up crank and took chunks out of bottom of cylinder walls. Guessing that block is **** now. I have another engine that I am going to be getting looked at and checked out to see if useable. The car ran...
I am new to this site and could use some help on a build I started. I have a 1988 convertible 2.3 auto very low miles and very clean. Only problem is a bad engine. I have a 1991 2.3 8 plus engine and I need to know what wiring issues I will have. I have the harness and computer are there any...
I have a 1995 cobra block just a stock 5.0 roller block that's been prepped bored .30 over now is a 306 cid with je pistons for 13.0.1 compression 4340 forged rods with 7/16 rod bolts good for 1000 hp @ 8200 rpm I know I will not make that power but still over kill is better then not enough...
