Put in a used T5 with all new clutch stuff (king cobra clutch, svo quadrant and cable). I'm at the end of my cable adjustment (tightened), and the thing barely disengages with my foot on the floor (as well as it being hard to push). Sometimes it seems to disengage almost completely with the pedal down just an inch or two, other times it seems to barely disengage enough to not grind with the pedal all the way down. Could a bent bellhousing cause a misalignment that manifests itself as a long and variable engagement period? Any suggestions? Thanks!
