I have a 1991 F150 4x4 AOD with a 5.0 Recently did the mass air conversion with a 92 C3W computer, 93 mustang harness that I spliced into my truck.
I did not pull the tranny to do the swap (I pulled the engine to do a mild build) The pinouts for the VSS on Mustang computer should be the same for the VSS on a 1991 SD truck.
My only inclination is that I need to change the original VSS with a 92 Mustang VSS... Before the conversion the speedo was working fine, now it does nothing.
