a friend of mine had his radiator crack on him and it overheated. he had it towed back to his house. since then the explorer won't start. it turns over fine, i checked for spark, and i can hear his fuel pump on. what would be the next thing to check. while your cranking the motor it doesn't even act like it wants to fire at all. any suggestions?
You have spark and fuel, check your IAC. It might be stuck closed. Will it start if you hold the gas pedal down slightly. Check your schrader valve at the fuel rail to see if you fuel, it could be a plugged fuel filter.
