any body got suggestions on truck will crank fine when cold but i can drive it 2 miles and switch it off and it will not fire. fuel pump is energizing and i have spark at coil wire on cap.
NEED MORE INFORMATION, we cannot read your mind. :) Pretty please.
Like WILL IT CRANK or will it NOT crank after 2 miles?
Crank Definition: ENGINE WHIRLING OVER AGAIN AND AGAIN WITH THE KEY IN THE START POSITION.
THAT is cranking over.
STARTING: When you crank your engine over and the A/F mixture combined with compression and spark cause ignition in the cylinders and releasing the key this continues to occur. :) :) This is starting your car. :)
You see, we need to get into your head, and your questions and statement left us wanting MORE information in order to help you. :)
Thanks!
