My TPS appears to be out of wack. When I push the clutch in to shift, the RPMs shoot up and stay there for a few seconds, sometimes much longer. I cleaned my IAC and it is ok. How do I test my TPS and adjust it if neccessary? Or is the TPS non adjustable? I also heard that it might be the Voltage Regulator but I don't think it would be the culprit since the high idling occurs when the throttle is pushed and released and when the clutch is pushed in.
Thanks,
BT
Thanks,
BT
