What other upgrades would you suggest. I have installed True Dual Exhaust, Cold Air Induction, Diablo Predator. Without adding a Supercharger, or changing the rear gears would changing the MAF be worth the money??
Thank you for your assistance!
no, you should be ok with the factory MAF.... a set of underdrive pullies would help....but the rear end gears will make a big difference...I dont know why u dont want to?
Unless you think that the MAF is saturating at 5V, no reason to change it. It has been a good sales "gimmick" and a lot of people bought in to the hype. Unless you make some other major changes, the stock one should be fine. You could always locate a shop, where they have a "Sneecer" to look at MAF voltage, injector duty cycle etc. Only way to know for sure.
Ron
