I have an intermitten problem with my 2001 Sable. Problem is every now and then it idle likes crap turn the wheel and it stalls any load on the motor makes it stall at idle. If you give it the gas it revs up no problems. I can't figure it. Let it sit and it goes way as fast as it comes. Any known problems what circuits / sensors control the idle. I did find a cracked breather line, leaves the valve cover and goes into the mass air flow sensor. Fixed it and problem was still there, but then later on that night it went away. ITS WIERD!!!! and FRUSTRATING!!!!
