Hi, brothers 2002 V6 mustang not running right. Starts good but when you accelerate at around 3000 rpm looses power. Then idles rough at 500 rpm. Fuel filter and pump changed. Any ideas ? Thanks !
Mitch
Could also be the ignition module. Not sure where they are located in an '02. Had a bad one in my 94, it would run great to about 4k then fall all over it's self.
Thanks for the help. When we were going in to clean the MAF we found the problem. Air cleaner was plugged with leaves. Cleaned out air box put in new filter, cleared codes and it runs good again.Thanks.
If it's the same as my '04 (3.9L) the module/coil pack is mounted on the passenger side of the upper intake. Hard to miss it. Cam synchronizer is a common problem on them, though. Takes the place of the distributor. The little turd V6 is similar to a B/RB Mopar. Kind of cool but still 2 cylinders shorter than what it should have been. Can't complain too much though. 275,000 on mine and still going, and 28 MPG to boot. Wish it were 30+ but it's a heck of a lot better than the Lightning
