A friend of mine has bought a 1963 Fairlane, with plans of a big block T-Bolt clone ( I know, its not a '64 ) question is, is the 221 in the car worth anything, or is it only worth junk iron price?
That is correct. They also had small valve 45cc chambers in the heads. Put them on a 289 with an RV cam and you have a high compression E85 fuel vehicle. The future of hot rods....oh yea my small block gets better mileage than yours.If I am not mistaken, the 221 and 260 use the same 2.87" stroke crank as the 289. So at least grab the crank as they are not that easy to find anymore.
They are different.question do 221, 260 and 289 pistons weigh the same with a 1/2 " bore difference from 221 to 289 with the same crank and balance for all of them?
Interesting info. I'm thinking of building a 221 for a Model A hotrod. Looking for an early 60The 221 block strength is similar to the 260 and 289 but the bore wall thickness is more than the 289 which caused problems with porosity. So, the 221 block is very good all round as is the 260. I first bought a 221 in 1975 for $5 and never regretted it. I personally only ever used cast Repco replacement pistons and never bored a block more than 0.060" but I do know of people who bored a 221 to plus 0.125" using alternative pistons - they never failed a bore. I limited the rpm to 6500rpm at all times although I did see the rev counter at 6750rpm quite a few times. I always kept the camshaft timing down to 280 degrees of duration seat to seat timing and not more than 0.500" of valve lift so the engine was making power from about 2000rpm which resulted in a very useful 4500rpm power band. I used an Edelbrock Torker 289, 360 degree inlet manifold with a 500 CFM Holley two barrel on top. Ignition was a Mallory twin point in conjunction with a Volt Master coil and ballast resistor. The crankshaft damper was off a 289 and I reduced the amount of external mass from 28.2 down to 23.1. This was of course when all of the weights were not really known.
