1 - 13 of 13 Posts
i have a tired old 289 in my 67 mustang i am restoring and i am putting in a 351 windsor and i need to know if 289 motor mounts will work and is the driveshaft length the same
289 motor mounts will work on a 351w, no problem.
I don't know what tranny changes you are making from the 289, but in general, yes the driveshaft can be the same length.
Think the yoke is different, not knowing the 'donor' car cant tell ya about the 'shaft length..
If I were a gambling man I would put my money on the 'shorten' list. BUT i dont know that for a FACT.... Maybe someone with a little more trans knowledge will chime in...
The 289-351s share the same bellhousing bolt patterns so you can easily swap the old 289 trans and flywheel onto the 351 if so desired..Are you sure the trans is a C-6 and not an FMX?
Discussion Starter #8
i have a c4 transmission but i guess the question is is the c6 better then the c4. and im not sure if it is a c6 for a fmx . if the c4 is the same or better i can just use one of those
C-6 is a one piece housing(bell-trans) FMX USUALLY bolt on bell and trans case cast iron. the c-4 will live fine if the 351 isnt a gazzilion hp'ed stroked out to a 427. That case it will need 'helping' but will still work.... there are advantages/disadvantages doing a c-4/c-6 comparo. Depending on end use.....
There ya go confusing the new guys again....;)
Discussion Starter #11
ok thanks alot i am going to put the c4 on it thanks for all the awesome information i feel better knowing this is available because i know nothing lol
1 - 13 of 13 Posts
