One set of 289 Ford heads. Casting # C5AE B. I have modified these heads and run them on two 302 cars, both with flat top pistons. I have machined these heads for the Chevy 1.6 exhaust valves and the Chevy 1.94 Intake, cut down to 1.90. New bronze guides. Valve bowls were matched to these valves. Intake runners were not enlarged, just cleaned up. Most work was done on exhaust ports.
ARP screw in rocker studs. Pushrods are guided in the heads with these castings so you have the option to run the early non rail rockers or any variation of roller or roller tipped rocker. Iski double springs good to .500”. View attachment 172151
