I have a 68 Torino that I want to get running. I don’t want to set any land speed records I just want a reliable mostly stock build. I’m not die hard on everything being just as it was in 68. I don’t really worry about performance just a cruiser. I’m looking for recommendations on a solid rebuild, what cam to use, and other things. I plan on using the stock heads most likely will use stock sized valves. I have a set of 351w heads with 194” valves not sure what year they are I know it makes a difference. If it can be configured simply and relatively cheaply I may go that route. I’ll have a machine shop build the short block and I’ll assemble the rest. Any advice is appreciated and I’ll answer any questions I can I’m sure I didn’t provide enough info. Thanks
